Cockshutt head bolt torque
Jerry @ Pullsit
05-28-2002 13:36:51
Had to pull the head on my Cockshutt 50 gas. Got the head gasket ordered, but looked thru all my stuff and can't find any info as to how much to torque the head bolts. Forgot to write it down 13 yrs. ago when it was off last...
The head's been milled but I can't remember exactly how much - thought it was .125", but my brother thinks it's more. But I do remember the shop telling me not to get crazy tightening the bolts down 'cause the head might crack...
Hope someone can tell me by Saturday - that's when it's going back together. Plan on pulling it the following day...
Jerry @ Pullsite
05-29-2002 11:34:44
 Re: Cockshutt head bolt torque in reply to Jerry @ Pullsite, 05-28-2002 13:36:51
Stopped by Coulter's in N. Branch, MI. They got out their AC D19 shop manual. The head on the D19 gas is basically the same as the one on my 50. It shows the torque as being anywhere from 110 to 120 lbs./ft. That'll work...
By the way, the head gasket is the same one used on the 230, 262 and 273 Buda engine. I had the Napa store check the part number to see if the 230 and 262 were the same - it's the same part#. The gasket works for the 273 as used in the 50.
Thanks for the replies...
Jerry @ Pullsite
05-29-2002 20:00:57
 Re: Re: Cockshutt head bolt torque in reply to Jerry @ Pullsite, 05-29-2002 11:34:44
Better not go that high on a 1/2" stud. Stripped one at 110 lbs./ft. Went back to Coulter's and had them look up the WD45 Diesel and D17 Diesel. Showed 70 lbs./ft. with a 1/2" stud on a WD45, and 90-95 lbs./ft. with same size stud on a D17. I went with 90 lbs. with no more problems...
Cookie
05-29-2002 04:57:54
I have the head bolts tightened down to 115 pounds with 20 thousands off the head on my 40 deluxe.
maxpuller
05-28-2002 18:00:51
If I can get my wife to look this week I'll mail you back or friday night when I get home for the week i'll check in my manuals I had my 40 apart last year and its in the 75lb range but don't take that to the bank till I check.
