Drawbars wheelie bars
Jim Johnson
10-04-2007 18:11:23
There was a big discussion on here a while back about a 460 Farmall that was on ebay. Someone made a statement about the fact that the wheelie bars and drawbar were not legal (NATPA rules) because they were connected. Someone, I believe from Minnesota, said that he had always built NTPA tractors and that they were legal in that association.
Well this got my curiosity up because it just did not seem like a safe way at all.If one or the other broke, especially at the speeds they run, it would be very dangerous.
Well anyhow I sent off and got a NTPA rule book to find out for sure.
Under Drawbars on page 20 it states rule # 13. Do not connect drawbars and wheelie bars.
So I guess that will end that argument and the old boy from Minnesota needs to redo the tractors he has built.
39f20
10-06-2007 19:13:39
 Re: Drawbars wheelie bars in reply to Jim Johnson, 10-04-2007 18:11:23
Ok i see where the difference is, im looking at NATPA rules and your looking at NTPA
39f20
10-06-2007 03:05:14
Sorry jimbo but the rule is number 3 and it says they Should not be attached to the drawbar, that means you can do it
Jim Johnson
10-06-2007 04:50:17
 Re: Drawbars wheelie bars in reply to 39f20, 10-06-2007 03:05:14
Rule # 3 in the 2007 NTPA rulebook is Eligibility.
The rule I'm refering to is under IV.General Rules-All Divisions E. Drawbars Starts on page 17 and on page 20 # 13 it states plainly Do Not Connect Drawbars And Wheelie Bars.
No where in that does the word Should exist.
DANG IT!
10-07-2007 20:21:18
 Re: Drawbars wheelie bars in reply to Jim Johnson, 10-06-2007 04:50:17
D*MN it now I have to come up with something different for my Farmall B! They are not welded together but the both share a bolt.
Jim Johnson
10-06-2007 05:14:07
Under Q. Stabilizer Bars # 3 states Stabilizer bar and bar assembly is not to be mounted to the drawbar and drawbar assembly.
If you look at the diagram they have it says under it, The stabilizer bars and their assembly are not in any to be connected to the drawbar and it's assembly.
That's exactly what it says.
