4010 weight reduction tips needed
alby15
10-23-2007 18:23:09
I have a 4010 alum frame,light front,lighter older rear axle housings.It still weighs 6100. ho can I get to run 5500
papuller
10-24-2007 13:31:57
 Re: 4010 weight reduction tips needed in reply to alby15, 10-23-2007 18:23:09
I have a 4010 non turbo on gas. it weighs 5300 with me on it (200#). it has SFI 3 bar rollcage and all. Before we had the cage, we contemplated hollow axles, lightening gears, etc to get down to 5000#. Some of the biggest gains:
Homemade console and dash
Aftermarket radiator
Aluminum brake pad plates
Fiberglass hood and nose piece (4320)
Aftermarket brake master cylinders
Reproduction fenders
BTW It is for sale if interested.
Brad
matt h ny
10-25-2007 09:57:00
 Re: 4010 weight reduction tips needed in reply to papuller, 10-24-2007 13:31:57
is this the one that was a the brookfield wheel days a few weeks ago? if it is then i was really impressed with how it ran. And if you dont mind why are you selling it?
Want a 4010
10-24-2007 20:46:32
Interested if it would compete with 6000rpm olivers and such.Also specks such as: cid.,gearing,and so on. Send or email pictures,location, price, an any other info. Thanks. PS. ph.# also, thanks.
pull watcher ohio
10-23-2007 18:49:25
there is a 4010 that pulls around west union OH in 5500 pd class. single front wheel henceforth the name 3 legged deer.
smdv806
10-24-2007 13:53:13
 Re: 4010 weight reduction tips needed in reply to pull watcher ohio, 10-23-2007 18:49:25
I know the guy that pulls that thing very well. He calls it a 3410. It has a 3010 rearend with 4010 frame rails. It has a 6620 combine motor in it as well. About every part on that tractor comes from a different tractor.
funny
10-23-2007 18:29:40
don't put a motor in it.
some guy who just is here
10-24-2007 17:37:22
 Re: 4010 weight reduction tips needed in reply to funny, 10-23-2007 18:29:40
Get rid of the fuel tank oil cooler and stock radiator. run a fiberglass nose piece. you could also put foam in the rearend. aluminum rims.
