Custom Flywheel company, DT466 on 560 Diesel
6780
10-25-2007 11:57:39
I need the name or Contact to a company that has made a flywheel for this application, DT466 engine on a 560 Diesel.
Any help is greatly appriciated,
Thanks
BradD
10-27-2007 07:16:38
 Re: Custom Flywheel company, DT466 on 560 Diesel in reply to 6780, 10-25-2007 11:57:39
I have a triple disk and sfi flywheel to put 466 into a 460/656. Set up is 9 months old. I may be willing to part with. I am considering changing set ups/class.
bm3501466
10-27-2007 09:38:02
 Re: Custom Flywheel company, DT466 on 560 Diesel in reply to BradD, 10-27-2007 07:16:38
Will that setup work with a 560? If so how much do you want for the clutch setup and flywheel?
BradD
10-28-2007 14:42:09
 Re: Custom Flywheel company, DT466 on 560 Diesel in reply to bm3501466, 10-27-2007 09:38:02
It would work but would need a different starter ring (larger diameter).
reborn binder
10-25-2007 20:44:16
6780 what is your class that u will run.is it going to be a go fast class or a mph class
JLB2
10-25-2007 14:30:37
ATLAS TRACTOR 763-780-9548 DAN OR CARL, OR RURSCH SPECIALTIES @ 309-795-1502. they have different options and both are good at what they do.mine came from rursch and i bought it used not directly from them. i know others have posted single disk will hold but i"m here to tell you it wont if you put gear enough to it,e-mail if you want to know more.my clutch set up came from atlas tractor
