730 JD rear wheel adapters to 9 bolt
zap
10-29-2007 09:41:06
Does anyone know where I can get rear wheel adapters for my JD 730 from the axle to 9 bolt pattern? Thanks for you help.
gpuller
10-30-2007 06:55:22
 Re: 730 JD rear wheel adapters to 9 bolt in reply to zap, 10-29-2007 09:41:06
Zap
You could put a wanted ad here in the classifieds for hubs. You should be able to get a set for under $200.
unstyled puller
10-29-2007 19:40:16
CALL BAKER, HE MAKES THE 9 BOLT ADAPTOR.
931-248-2782
gpuller
10-29-2007 13:27:28
You need to find a set of M&W or factory Deere dual hubs for a 4010, 3010, 3020...etc that had a 3 1/8" dia axle. My guess is that the M&W hubs would weigh less than the factory hubs.
zap
10-29-2007 15:18:58
 Re: 730 JD rear wheel adapters to 9 bolt in reply to gpuller, 10-29-2007 13:27:28
Where would I get the M&W hubs. I know that I can probly find the JD hubs.
R Moline
10-29-2007 17:52:33
 Re: 730 JD rear wheel adapters to 9 bolt in reply to zap, 10-29-2007 15:18:58
I think we still have a set of 3 1/8 M&W hubs. They are in good shape but will need a few studs.
