48 JD A Stock Block Bore
Bore
10-29-2007 16:09:22
Whats the biggest bore that can be put into a stock JD A block. It's an early Cyclone A with the Hi/Low. I found a set of 720lp pistons that I would like to put in. I've searched and found that 720's are a 6" bore. Is this possible to fit inmy A? and what would have to be done to work Sleeves?, Hardblock?. Thanks Guys
Mike n Mo
10-31-2007 07:45:56
 Re: 48 JD A Stock Block Bore in reply to Bore, 10-29-2007 16:09:22
What year is your A? I've got a couple of power blocks I would sell that would fit that would give you 6 to 6.125 bore. Mike
Mike n Mo
10-31-2007 07:50:18
 Re: 48 JD A Stock Block Bore in reply to Mike n Mo, 10-31-2007 07:45:56
Sorry, if I read the title it said 1948. The power block I have for that year needs dry sleeved back to a 6" bore. E-mail if interested
Bore
10-30-2007 20:16:28
How much is it roughly to get an A block bored and sleeved to put 6 1/2" pistons in it. How reliable would this be
Drew
10-30-2007 20:30:37
 Re: 48 JD A Stock Block Bore in reply to Bore, 10-30-2007 20:16:28
To get a stock block resleeved to 6.500" will be give or take $1200. It may leak water, it may not.
Murphys Motor Service will have NEW 6.500" A power blocks for A's available in coming months.
buickanddeere
11-02-2007 06:17:06
 Re: 48 JD A Stock Block Bore, address in reply to Drew, 10-30-2007 20:30:37
I keep losing the address of the shop that does custom oversize sleeves on two cylinders. Do have it handy?
jd b puller
11-02-2007 06:44:07
 Re: 48 JD A Stock Block Bore, address in reply to buickanddeere, 11-02-2007 06:17:06
B&D I think you"re looking for Jack"s in Hooper, NE. (402) 654-2217.
I"ve got NEW 6.125" B Blocks about ready.
skip 33652
10-30-2007 06:53:49
there have been some guys put 5 7/8" (70 jd) pistons in early A blocks with the right block and ultra sound you might get that done.Paul
jd b puller
10-29-2007 17:55:11
6.75" if you resleeve it. 5.75" if you just bore it.
