Hot Farm Class
Jack Feller
05-31-2002 11:11:45
I have a chance to buy a IH 1066 or a JD 5020. Which tractor would be better for pulling with. Most people around here pull IH's. The ones who pull JD's are 4430's and such. How much horsepower do these tractors haved stock? and what about building them to get the most horses out. Which would be cheaper to work on and still be competitive. Thanks.
tractor puller
08-13-2002 08:11:30
 Re: Hot Farm Class in reply to Jack Feller, 05-31-2002 11:11:45
i would go with the 5020.if you put a 619 in it.And make it a 6030. A 1066 will turn a lot of rpm's but the the hot farm class has a 3000 rpm limit and a 619 will turn that.you will have to take the weight off.i got mine down to 8500 pounds.you might also need to a splitter gear in it because 7th is to slow and 8th to fast.you can put 466 rods in it and get the cubes up to 680.
it just easy hp and you will end up with a lot more cash in your pocket.
Puller504
06-20-2002 19:08:13
The 1066 should have the torque amplifier, which will give you shift on the go if you want. The 5020 JD has an 8 speed synchro, no shift under load, but factory has a larger motor (your choice)Hey David, when are you going to start pulling the Ferguson 165? Joey and your Dad have had all the fun. Kay wants to take you on with the stompin' 504, she may pull the Oliver yet this year.
David Berger
06-10-2002 19:00:20
jack,i gotta agree with these guys,youre better off with the 1066,and im a massey fan!i wouldnt modify it,but....the 1066 is a great pulling tractor in heavy classes.ive seen people all over ohio do good in pulls with 1066es.good luck!
david
David Berger
06-10-2002 19:00:19
david
allisguy
05-31-2002 18:17:11
Guys, Name calling is not necessary.
Cookie
05-31-2002 14:12:45
Each tractor has it's pro's and cons but a 1066 is the better buy in my opion.The 10 has part avaibility, weighs less, easy to get the rpm's, more wheel speed,and a little cheaper.This all coming from a Deere guy.
tim
05-31-2002 12:11:19
In my opinion, you can buy lots of horsepower for either tractor probably for about the same amount of money that is horsepower/dollar. However, from what I have seen, it is easier to lighten the 1066 to run in more classes than it is to lighten the 5020.
I also just posted on the farmall/international forum a 1066 for sale. It is a beautiful tractor with very low hours. Next week I will get it into the classifieds with pics. and so on. The owner of this tractor could get you set up very well for pulling hot farm with this tractor.
Is this text...
05-31-2002 12:57:15
 Re: Re: Hot Farm Class in reply to tim, 05-31-2002 12:11:19
Is this text at the top of the page for a reason?
'This is a moderated discussion board. No Advertising of any kind is allowed here. This includes For-Sale and Wanted-To-Buy items. Use the classified ads page for these.'
tim
06-06-2002 08:16:14
 Re: Re: Re: Hot Farm Class in reply to Is this text..., 05-31-2002 12:57:15
I'm sorry to upset you, I am new to this board and didn't know that you weren't supposed advertise on here, I am working on scanning some pics of the tractor and will have a legitimate ad in the classified section soon.
tim
06-06-2002 08:16:08
You Moron
05-31-2002 15:50:47
I dont see an add i see a discussion about an add and some advice pertaining to the question that was asked. Go bother someone else with your whining.
Wheels
06-01-2002 11:27:06
 Re: Re: Re: Re: Hot Farm Class in reply to You Moron, 05-31-2002 15:50:47
Over on the Farmall board it's an add.
This seems to be typical of some pullers, "the rules apply to the other guys"
I am glad someone else is getting sick of Ads not in the classifieds.
Wheels
the moron
05-31-2002 21:38:29
Yes, I am truly sorry.
kevin
05-31-2002 19:19:48
i would deffamitly go with the 1066 it weighs less its easer to turn up looks better gets better weight transfer then any john deere and if you decide to go super stock later on down the road its a lot easer to modafy you can always take the rear out of a 1566 or 1586 to get better gearing in heavy classes and the TA is a big help. hope i help anserd your qustin. ~ Kevin
