MSD boxes
Flyin Farmall
06-03-2002 17:09:25
how many of you guys use them??do they make much difference??are they worth the$$$?I seen alot of them in Columbia and was wondering about the benefits.thanx!!
Flyin Farmall
06-04-2002 18:32:25
 Re: MSD boxes in reply to Flyin Farmall, 06-03-2002 17:09:25
Thanx guys,thats what I needed!!!it's nice to get actual advice instead a bunch of B>S.does anyone have a tach,or know where to get one thats for lower rpms??maybe 4-5grand.
burns
06-04-2002 19:34:12
 Re: Re: MSD boxes in reply to Flyin Farmall, 06-04-2002 18:32:25
FF, I bought mine from summit racing in 9/00. The part number is ATM-2890 and is currently selling for $81.39. I really like the tach as it is back lit which I wired in conjuction with the ignition switch. It is compatible with a MSD 6A box. On the 6A unit, there is a port which directly connects to this particular tachometer. Link shows the tach on my G and a close up of the face.
Hope this helps [Can't believe I'm helping the Red enemy ROFL]
BTW by adding a tach, the grandstand mechanics will add an additional 50hp on top of whatever you are producing and another 50 if you have paper filament and chrome stacks. LOL
Flyin Farmall
06-04-2002 19:57:27
 Re: Re: Re: MSD boxes in reply to burns, 06-04-2002 19:34:12
thanx!that's why I want one ,for the x-tra HP!!!lol
HEY FLYIN FARMALL
06-05-2002 03:48:59
 Re: Re: Re: Re: MSD boxes in reply to Flyin Farmall, 06-04-2002 19:57:27
I forgot to tell you that the seal around the glass is not waterproof. I ended up sealing it with some silicone after I spent a couple hours getting the condensation out of the housing.
Burns
JCM
06-04-2002 15:04:20
I WOULD RECOMEND ONE. I HAVE MODEL 6A ON A 400 FARMALL.THE FIRST THING I NOTICED WAS SMOOTHNESS OF THE ENGINE AND BETTER RESPONSE. IVE ONLY PULLED ONCE SO FAR WITH IT BUT I'M TRYING TO FIND SOME TIME TO PUT IT ON A DYNO AND SEE WEAR IM REALLY AT.BY THE WAY ANYBODY TAKE NOTICE TO THERE PLUG GAPS THEY RECOMEND? UNDER 10.5:1 COMP. SET PLUGS AT .050-.060 .MY 400 HAS 4 1/8 SLEEVE KIT BUT THATS IT NO SHAVED HEAD OR DECKED BLOCK I MIGHT HAVE 7.0 COMP. WHAT GAPS IS ANY ONE ELSE OUT THERE RUNNING WITH A SIMILAR SET UP? ISET MINE AT .045 BECAUSE IT SEEMS WITH THE WAY MY TANG IS SPREAD AWAY FROM THE ELECTRODE ITS MORE HARM THAN GOOD..ANY INFO APPRECIATED.
Mike F
06-04-2002 10:58:17
I thought all msd boxes had the multiple spark? It says on my #5 box "multiple spark discharge".
jdeereg
06-04-2002 07:18:40
I am using one on a JD G and have had very good luck with it. I would recommend the 6A box for the best performance for the price. The 5A does not have the Multiple Spark that the 6A does and the 6AL is more difficult to install and is overkill for a tractor.
burns
06-04-2002 12:58:07
 Re: Re: MSD boxes in reply to jdeereg, 06-04-2002 07:18:40
There is very little difference between the 5 & 6 units. The 5 is limited to 6,000 rpm and the 6 maxes out at 15,000. Physically they share the same dimensions. Both provide multiple sparks for 20 degrees of crankshaft rotation. However, the 6 does provide about 5,000 more volts out of the secondary. I agree that the 6 would be a better choice over the 5 but I don't disagree on the 6AL being more difficult to install. The rev limiter is the only difference between the 6A & 6AL. These chips are interchangeable but really don't do us JD guys any good being the 6AL comes with 3,000, 6, 7, 8,000 chips. I do know other rpm limits are avaliable. If you are running a 4 or 6 cylinder and you engine is maxed out, yes I think it would be money well spent.
BTW, were do you pull at? What year is your G?
jdeereg
06-08-2002 09:03:30
 Re: Re: Re: MSD boxes in reply to burns, 06-04-2002 12:58:07
Sorry about the mis-information. The 6 series boxes are the entry level for the capasative discharge. That was the main difference that I was thinking of. I just do not see the need in paying the extra cash for the rev limiter in such low rpm applications, but to each his own. My G is a 1938 and I pull with the East Tennessee Antique Tractor Assocation.
burns
06-04-2002 04:07:39
As your psi reading goes up on a performance engine, the need for a good strong hot spark is needed more. Plus you get a bonus with the added assurance that you have a more complete burn on the gas/air mixture in the cylinders. You can also increase your plug gap as much as .010. I would suggest a quality set of wires to compliment the electronics. There is no sense in running a 225xR75 15" tires with a 600 hp big block under the hood.
hank
06-04-2002 01:04:10
they should be standard equipment on all new
gas powered equipment, they seriously improve
performance bigtime. i have used them on my
race cars for years and also on my pickup truck.
craig
06-03-2002 20:53:32
MSD is alot cheaper, and is a great system, mine has a Jacob's on it and had good luck out if it so far, my 2 cents worth.
randy hall
06-03-2002 20:36:28
we have one, it will help a hard starting tractor fire up easier. sometimes when it is warmed up it will start on its own without the starter, like a model t that is tuned up real good.
Mike F
06-03-2002 20:30:38
I use one on my JD A. It is the #5 series and it is the cheapest, It has worked good, no real power product, but I don't foul plugs like I used to, starts fast too. It has definitely saved on the cost of plugs.
Dave N
06-04-2002 05:22:42
 Re: Re: MSD boxes in reply to Mike F, 06-03-2002 20:30:38
I have used them with great success.The Higher comp. you run the hotter the spark has to be. Word of warning with the MSD your tractor can start up just by turning the key on. So always be on the tractor or make sure it is in neutral.
