Front end
Puller Man H
11-20-2007 09:54:45
Is there a hub conversion to make stock H front end insto a hub for press steel. Right now i got a man made one and rules are changing. So any help to know what hubs i can run would be great
Ed Hodge
11-22-2007 15:24:10
 Re: Front end in reply to Puller Man H, 11-20-2007 09:54:45
john deere B front hubs will work i have a set on my farmall H
ChadS
11-20-2007 17:16:09
IH 6 bolt plow hubs,,, like the tail wheel. Most of em had the same inner bearing as the H, and really close on the outer bearing, too big,, I took the old H outer bearing, shattered the rollers and used the race as a shim to fit inside the plow hub bearing. Ya have to cut the edge off the H race so it fits inside the other race,,, but worked out beautifully! Took a set of rims off a IH baler, 4X15, put on a set of 4.00X15 tri rib tires, made it look like it belonged there! Hope this helps. Chad
MJF
11-20-2007 15:12:06
I've been told a 300 utility hub will fit on an H with some bearing swapping, but I've never tried it. Hope it helps
MIKE FRENCH
11-20-2007 12:28:51
If you change the bearings, a IH 6 bolt hub will fit with a little work, have to match up the spindle size to fit the race in the hub, a bearing store or good parts place can help. I put a set of MM Z front hubs on a CC case so anything can be done.
AC
11-20-2007 10:49:00
scroll down a few days and see the post I wrote on here abou one for an M...it works the same way.....AC
Puller Man H
11-20-2007 11:41:28
 Re: Front end in reply to AC, 11-20-2007 10:49:00
Ac. There is no hubs that will go on an H front end? Just on a c tower?
Barnheater
11-20-2007 13:57:58
 Re: Front end in reply to Puller Man H, 11-20-2007 11:41:28
460 front end should be the same as an H & has 6 bolt hubs.
Puller1
11-20-2007 14:10:14
 Re: Front end in reply to Barnheater, 11-20-2007 13:57:58
460 frontend will not work on an H the 460 will bolt right up to a M though
