Allis WC
ALK-AC
11-27-2007 05:36:40
I"ve got an Allis WC I"m thinking about building into a antique stock puller. Would I gain more power by shaving the head a tenth, or by putting an oversize kit in? Its an unstyled hand crank start. If I did both, how dificult would it be to crank start? Thanks
getagoodun
11-30-2007 15:43:44
 Re: Allis WC in reply to ALK-AC, 11-27-2007 05:36:40
If I was u I would get a real tractor to start with like a good JD are Oliver maybe a hot CS
1000yds
11-28-2007 17:00:12
Easiest way is to find an E Gleaner combine engine. Bolts right in and makes it an awesome puller.
slowsmoke
11-27-2007 15:30:26
lots of info in the archives. I had 1 with 45 crank, and 4 1/8" flat tops. hand started it for a year, not too bad, but I'm glad I went to electric start.
Kip-Utah
11-27-2007 13:12:09
On a WC the combustion chamber is not in the head, so the only advantage in doing this is to make sure that it's flat, as it will not boost your compression. Just use a good 41/8" kit with something like 6.5:1 or 7.25:1 compression ratio. It will probably crank start easier. Kip
