ChadS
12-06-2007 09:00:16
Re: Farmall M 1946 pistons in reply to Paul Mockensturm, 12-04-2007 19:54:27
A 450 kit in the M block is best option,, makes a 281ci out of it. Lots of options after that point to make good power.
Best advice is to make a Super/450 internally,,, when the SM came out with the 264 block, allowing the 4.125 overbore, you seen a change in the entire engine design, Bigger displacement, higher compression ratios, different styles of pistons, etc etc. But standard, you seen more of the options, factory upgraded parts more in the 400-450 C264 and C-281 engines. Upgraded parts start at the Super M,,,, the block was able to go to 281 ci by swapping the sleeves, also firecraters were really gaining popularity, and you started seeing more SMTA's with firecraters, some were ordered that way, most were dealer conversions,,, but alot of the 400-450s I have been into have had firecrater pistons. But anyways,, another upgrade was the cam grind,,,, they did change it in the SM,, some argue as to when it came out,, but the more popular phrase for the cam is the 450 cam. Ive seen this 450 cam grind in SM's as early as serial number 5000, with the right handed nut,, I took one out and had it checked, or read to see what it was exactly, and sure enough,,, compared to the M, it was not the same grind. But mostly common in the 400-450 tractors. Carbs changed design as well when the 400 came out,,, and the governor changed just a bit,,, either carb will work fine, but you have to build the older carbs to match up to the newer carbs,, Hope this helps open up a door,,, as they got newer, they upgraded and upgraded, but everything can be done to a M with a little work, and what a tractor it makes out of the ol M!!!!! I know, I got one! LOL!! 70+ hp on 87 octane pump gas with a 8060 head. ChadS Email is ChadS3@hotmail.com
