Farmall pullers
Gene Williams
12-17-2007 14:42:53
I understand there is an international truck engine that without a whole lot of modification can be put in a 560 that will bring it up around 400cid. Does anyone know what engine it is and what has to be done to get it in there.
Super 77 Puller
12-27-2007 16:31:30
 Re: Farmall pullers in reply to Gene Williams, 12-17-2007 14:42:53
I have a rd 501 i would sell, dont know anything about it, theres no manifolds but the head and block are there i think it turns over. $250
J.C.in AZ.
12-18-2007 14:40:19
The 460 and 560 IHC engines are of the BD[Black Diamond] Engine Series. They are basically Truck Engines modified for Tractor use.I don't know if they share Bell Housing Flange Patterns with an RD[Red Diamond ] Engine Series or not but it should not be too hard to determine using the BD to RD Specifications if you can find them. The BD 308 was a common class 7 Truck Engine. I had one in an A 180 Single Axle Truck Tractor. The BD 308 was used for other applications also. IHC had an SD [Silver Diamond} Engine Series also but they were used in light Trucks.
tenn
12-18-2007 04:42:43
I have a RD450 for sale, $ 400 in Tenn.
Haird7
12-18-2007 19:49:40
 Re: Farmall pullers in reply to tenn, 12-18-2007 04:42:43
What kind of shape is the motor in and what part of Tenn. are you located?
gene williams
12-18-2007 15:19:40
Tenn is your engine lose tenn and mike were the engines runing on nat gas
MIKE FRENCH
12-18-2007 20:11:24
 Re: Farmall pullers in reply to gene williams, 12-18-2007 15:19:40
Mine was on gasoline only, would take an offer on mine if any one is interested, thanks
Haird7
12-17-2007 16:04:36
An RD450 and 501 will work in a 560. We are also learning about this swap so I'm sure someone with a little more knowledge will chime in. I know you have to have a flywheel made!
MIKE FRENCH
12-17-2007 16:26:05
 Re: Farmall pullers in reply to Haird7, 12-17-2007 16:04:36
got a RD450 for sale if anyone is interested. Not stuck, was a irrigation engine, email for more info.
Haird7
12-17-2007 18:36:34
 Re: Farmall pullers in reply to MIKE FRENCH, 12-17-2007 16:26:05
How much and where at?
MIKE FRENCH
12-17-2007 19:03:50
 Re: Farmall pullers in reply to Haird7, 12-17-2007 18:36:34
NW MO in little town called Craig, $500OBO, has homemade exhaust manifold with twin pipes(They did a nice job)
