JD 50
52 A Boy
06-09-2002 05:58:31
I have a 1952 JD 50 that I pull with and was wondering if I could put a 520-530 head on it and if I could what would I have to change out.
Thanks for any info.
52 A Boy
Ron
06-10-2002 20:02:35
 Re: JD 50 in reply to 52 A Boy, 06-09-2002 05:58:31
Don't waste your time with the head change..!! I have a '52 "B"---Granted, it is +.180--But... it will definitely out work AND out pull my '57 520.....and the 520 is a good tractor...
G Taylor
06-09-2002 06:54:46
A 50 with 520 heads would look odd with two spark plug holes per cylinder.
David Ransom
06-09-2002 07:48:11
 Re: Re: JD 50 in reply to G Taylor , 06-09-2002 06:54:46
Would it work that way?
G Taylor
06-09-2002 15:34:39
 Re: Re: Re: JD 50 in reply to David Ransom, 06-09-2002 07:48:11
Measure the piston deck heighth and combustion chamber volumes. A 50 block with 50 pistons and a 520 head would have a compression ratio of about 3-1/2 to 1.
06-09-2002 19:06:23
 Re: Re: Re: Re: JD 50 in reply to G Taylor , 06-09-2002 15:34:39
A 520-530 head won't bolt on to a 50 block.
