Eliminating a Torque Amplifier
460 IN VA.
12-21-2007 06:40:26
Does anyone know of a do it yourself way to eliminate the torque amplifier in a 460 farmall?
Also, do these give problems on pulling tractors if left alone?
460/560
12-21-2007 15:36:11
 Re: Eliminating a Torque Amplifier in reply to 460 IN VA., 12-21-2007 06:40:26
I"d advise you to leave the TA in your 460. If you have any trouble with it slipping, you can add more springs to the pressure plate on the TA, that will help it hold better if you have problems.
dale d.
12-21-2007 07:03:33
i have one in a 460 and had no trouble in 6500,7500,8000# class.414cid. stock rpm.
dale d..
12-21-2007 19:17:38
 Re: Eliminating a Torque Amplifier in reply to dale d., 12-21-2007 07:03:33
ps, i also run 18.4-38 radials. if you have trouble have it rebuildt it not the worst $$$$$.
460 IN VA
12-22-2007 07:46:27
 Re: Eliminating a Torque Amplifier in reply to dale d.., 12-21-2007 19:17:38
Thanks again dale d. and 460/560. I think we have made up our mind. My son has been pulling a DC case in the stock class and this is our first Farmall. We have a new set of rollers and springs for the ramp, so we will put her back together as is. Again Thanks!
460 IN VA.
12-21-2007 08:09:36
Thanks dale d. This is the kind of info. I am
looking for.
