Big cube 820/830 JD
toolz
12-28-2007 21:16:12
I'm curious about what it takes to get 800-1000 cu. in. in an 820/830 motor. Do they use aftermarket blocks? What has to be done to the crankcase? This isn't something I plan on doing in the near or even distant future- just wondering how it's done. Thanks for the help- Kevin
buickanddeere
12-31-2007 09:23:00
 Re: Big cube 820/830 JD in reply to toolz, 12-28-2007 21:16:12
What class are you pulling in? Stock cubes can make a bunch of power. If the cam & followers are trued up and ground for some extra lift/duration. The valves and valve bowls done with a five angle and de-burred/de-flashed. Ports matched to manifolds. Aircleaner converted to a dry filter. Then get the injection pumps souped by Albert at Renaissance Tractor in Washington State. The low pressure fuel forwarding pump/relief setting has to be at least 60psi at all power levels. The resulting HP level is "lots".
toolz
12-31-2007 16:21:29
 Re: Big cube 820/830 JD in reply to buickanddeere, 12-31-2007 09:23:00
Thanks for the info- I'm just pulling in stock, first gear only, so lots of horsepower isn't much of an advantage. I was asking the questions for curiosity only, but may do something in the future. I just like to learn what I can, and there is lots of knowledge on this site. Thanks again for the help. Kevin
toolz
12-30-2007 20:20:05
Thanks for the replies. How far can you bore a stock block? Kevin
hahter
12-30-2007 20:25:06
 Re: Big cube 820/830 JD in reply to toolz, 12-30-2007 20:20:05
The tech manual says the max is .125 over. If you have a very good block you might can go bigger, but watch your water jackets. Hopes this is helpfull. Terry
Just Glory
12-29-2007 05:29:42
Well you could go with a billet crank and get those kind of cubes I'd imagine, but a friend of mine who builds John Deeres says the problem is getting enough air to them to utilize the cubes.
hahter
12-29-2007 03:08:35
I would not stroke the engine. The cranks in the 820/830 JD are hollow and will break. The 820 my father has that we pull has been bored .125 over with 830 pistons and head. It also has a custom fuel system and injectors built by Garry Powers out of Texas. Garry Powers actually built this tractor. There are a couple of pictures of the tractor on the Tractor Photos gallery under 820.
deere puller
12-29-2007 07:34:10
 Re: Big cube 820/830 JD in reply to hahter, 12-29-2007 03:08:35
have seen them with over 10" of stroke. they run GOOD!!!!! !
hahter
12-29-2007 03:10:34
I forgat to mention that the engine is around 790 CI. Hope this helps.
Terry
buickanddeere
12-28-2007 23:07:02
There was somebody custom casting massive blocks with 8 inch bores if memory serves. Lost the data in a computer crash.
LW
12-30-2007 10:53:39
 Re: Big cube 820/830 JD in reply to buickanddeere, 12-28-2007 23:07:02
Larry Carlisle, 8" bore no water, 2 passes back to back and she would have to sit a while.
deere man
12-29-2007 18:55:29
I believe a guy in carolinas had blocks that were 8.5 inch bore!!If you look in old HOOK magazines you'l find the add!!!
deere puller
12-29-2007 07:32:22
John Jones Odin IN.
