530 case motor in a vac????
lafngas
01-07-2008 09:02:30
Ok is the motor the same in a 530 case and a vac thay look the same does a 530 make more power is this a easy swap i have a 530 motor out of a industral tractor and a vac with a dead motor thought about a 2600 pound puller
dctom
01-07-2008 15:50:34
 Re: 530 case motor in a vac???? in reply to lafngas, 01-07-2008 09:02:30
yes it can be done i have put 201 out of a combine in vac's, it is the same block as a 530 takes a little work but caan be done e-mail me tom
Oliver Puller
01-07-2008 20:04:23
 Re: 530 case motor in a vac???? in reply to dctom, 01-07-2008 15:50:34
I don't know anything about a 201 but a 530 block is not the same as a vac. The vac block is shorter by about 1/4". The crankshaft in a vac is also shorter. The crankshaft on a 530 has more material between 4th rod journal and the 3rd main journal. A vac crank will not fit in a 530 or vice versa. Also the top engine mount bolts on the 530 are farther apart than a vac. I am not saying it could not be done but putting a 530 in a vac is not a bolt in job.
Oliver Puller
01-07-2008 13:52:09
I believe the motor out of a 530 is different and will not fit. If you look at the block casting around the starter, the 530 will have a ring cast around the starter and the vac won't. I believe the bolt pattern is different too. A motor out of a 200b or a 300b will fit in a vac though but the motor is just a little longer but will work. I put a vac motor in a 200b once.
