Alumminum weights for pullers, and used parts
Trac-mania
06-11-2002 17:59:32
looking for look-a-like IH 100lbs. alumminum weights, to fool competitors, call 412-331-2992 if have any. Also own tractor repair and savage yard so if you need any parts give us a ring.
Andy
06-13-2002 07:56:00
 Re: Alumminum weights for pullers, and used parts in reply to Trac-mania, 06-11-2002 17:59:32
Just woundering, the difference in price, of a real weight, and a alummium weight, like the IH, or JD. don't need any, just woundering, Yea wood would be a lot cheaper.
burns
06-13-2002 07:09:06
I don't know about you but it seems like more work than it is worth to fool a couple pullers by casting aluminum weights. I keep my little notes from previous pulls on the weight distribution, drawbar length/height, chain length, type of sled, track conditions, and tire pressure. I go by what my tractor pulls. Hey maybe the competition has fluid in the front tires which effects how they look? Maybe the competition pulls with a near empty or full gas tank which obviously effects the weight distribution. Sure you can tell a lot by how the other tractors pull but I don’t think someone is going to add 800 pounds of weight just because someone else as a full weight bracket.
Andy
06-12-2002 20:42:44
an alumminum weight 15x20 2in. thick would weigh about 50lbs,
Scott
06-12-2002 19:51:20
They have been around for years. a lot of guys in super stock like them for splitting up there wieght they normally wiegh about 25 pounds and they still fit and look like the rest of your wiehts. They were making some nice ones out of fiberglass too more as a gag or to keep the competition guessing as to how much wieght they were running.
David Ransom
06-11-2002 21:08:08
You want a fake weight that's light but makes your tractor look heavy so you can go into a lighter pull class and maybe possibly spin your wheels?
Could you maybe make them out of wood?
You are not going to fool anyone now !
06-11-2002 18:45:08
ARE you?
