Farmall M cylinder head
LN
01-11-2008 17:35:13
wanting to know what are the biggest valves anyone has put in an 8060db Farmall M head
and where did you get them, also what type of springs and spring pressure are you running
How much should you machine off the head and be safe I have heard .100 to .125 is about the max. and still have some reliability
james rumph
01-11-2008 19:00:23
 Re: Farmall M cylinder head in reply to LN, 01-11-2008 17:35:13
I had a 8060 head with .125 milled off it and it devoleped "6" cracks due to the ammout removed . Magna flux your head before you do anything .
When you cut that much off a head you end up making shims of the same thickness to go under the pedistals to keep the rockers at the correct level for adjustment .
