7inch stroke in farmall m
gts
01-14-2008 16:19:17
will 7 inch crank fit 4.25bore with h rods and what would be a good piston to yous thanks
super mta puller
01-15-2008 10:49:37
 Re: 7inch stroke in farmall m in reply to gts, 01-14-2008 16:19:17
I have built a couple.AT 6.5 you are getting into the cam pretty bad with stock rod.Also rod length enters in .Definitely use a custom rod.If youy can afford to build a stroker you can afford to do it right.Save youy a lot of grief.
superih
01-15-2008 09:58:41
You can use an M rod just narrow it and remove access material from rod cap and clearance block, this is the cheapest way to go and you will not break a rod. If you use H rods be sure to box them.
Charles E. McNelly III
01-14-2008 17:32:04
Your best bet would be to contact Murphysmotor service.com, they build this set up using custom rods they make. If I could afford it, I"d already have it. Good Luck.
Charles
AC
01-14-2008 16:48:25
Im think the problem may be at the bottom of the bore. 4.375 x 7 with a 450 rod gets into the bottom of the bore a little bit. The H rod is smaller, and might make the difference, but I still but it will be tight. Dont take it from me, I've never built an M in my life, but seen a couple being build here and there. (and someone on here thinks I'm an idiot..lol).....AC
01-15-2008 05:40:56
 Re: 7inch stroke in farmall m in reply to AC, 01-14-2008 16:48:25
More than someone more like someone's
AC
01-15-2008 10:30:45
 Re: 7inch stroke in farmall m in reply to ???, 01-15-2008 05:40:56
well, dont hesitate to show "yourselves"..till then, it's been nice having power over you..
#2
01-15-2008 11:19:09
 Re: 7inch stroke in farmall m in reply to AC, 01-15-2008 10:30:45
Go away AC!
AC
01-15-2008 12:38:55
 Re: 7inch stroke in farmall m in reply to #2, 01-15-2008 11:19:09
I will when you girls..er..guys make your names known to me. Savvy?
