Farmall 460?
the tractor kid
05-05-2001 08:56:38
hi im fourteen and am going to get a farmall without a motor ta pull in a few shows and graddually work up the tractor. so what is the best motor to put in a farmall 460 widefront?
Mike
05-14-2001 13:28:28
 Re: farmall 460? in reply to the tractor kid, 05-05-2001 08:56:38
start slow and remember to have fun. When I was your age we had a 460 D that was somewhat "adjusted" It would dyno 175 hp on diesel w/o alcohol(we ran on the track) Then we got serious and stripped it(no more PTO to dyno) and it got stronger. We were always in the money but rarely a threat to win. To win you need srious money, we were just out to have fun and maybe make gas money. Good luck and enjoy yourself
460puller
05-08-2001 20:23:44
A 460 is a great start try to get and engine out of a 715 or an 806 these blocks have no sleeves and can be bored to just over 4 inch with no worries or water leaks mine pulls 3500 with a T/A, 3750, and 4000 Division 5 (NATPA RULES) a 460 works great anywhere form 3500 to 5500 depending on what class and what modification is allowed weight ration is a little out of balance in the lighter classes, you may need to take some off the front and put it on the back. Anyway you got a great tractor to start with and a motor that has alot of potential Good Luck
KB
05-07-2001 05:51:14
Get the motor from an 806 or a 715 international combine and go from there.
baystatebinder
05-06-2001 06:42:18
put in a ih 301 out of a 806.
t
05-06-2001 15:05:48
 Re: Re: farmall 460? in reply to baystatebinder, 05-06-2001 06:42:18
First decide what class you want to pull.
Ross
05-10-2001 19:16:40
 Re: Re: Re: farmall 460? in reply to t, 05-06-2001 15:05:48
I am 16 and I have actually been looking into a 560 without a motor too and I was going to put a 301 in it out of a 715 combine and go from there. It's a good starting point with a lot of power to build up on. Good luck!
