200hp. 1206
BAD ATTITUDE
01-20-2008 16:25:33
What is the easiest way to get 200 horse from a 1206? Thank you in advance.
ejr-IA
01-21-2008 18:04:39
 Re: 200hp. 1206 in reply to BAD ATTITUDE, 01-20-2008 16:25:33
Yes on the manifold if it is the large base pattern.It will take some mods but not bad.
ejr-IA
01-21-2008 12:32:07
I hve a 390 head Roosa with 4100 hundred 429 IH 4 wheel drive injectors and a 3lm466 turbo that will get you their easy.The lines on a 1206 are big enough.
BAD ATTITUDE
01-21-2008 14:07:14
 Re: 200hp. 1206 in reply to ejr-IA, 01-21-2008 12:32:07
Will the stock manifold work with a 3lm466 or do you have to switch to the 66 series manifold? Thank you.
856 puller
01-21-2008 05:38:21
i dont know if you can get there with a stock inj pump. but if you call st joe diesel or some good hi performance place they can change the head and rotar to something that will work. if youu get the pump done you might as well go to a .450 head right away .you will want to get bigger tips and maybe lines.
