435 JD
Vic
02-02-2008 15:47:38
Does anyone pull a 435 jd ? what weight class
Vic
02-04-2008 17:50:53
 Re: 435 JD in reply to Vic, 02-02-2008 15:47:38
Thanks for the come back guys. I"m building a 435 but I haven"t had a chance to weigh it. I was shooting for 3500 lbs. I"ve taken off everything that will come off. thanks again.
local puller
02-03-2008 11:54:53
Their is a guy in missouri that pulls one in the 4000, 4500,and 5000lb classes seems to be very competive. e-mail me your phone # and we can help.
buickanddeere
02-03-2008 06:22:23
4500lb class but the 4000lb class would be better. Not a lot of HP and 1st gear is very fast. The engine is rather heavy so a long stiff drawbar is required to transfer weight . On a clay track I can place well but on a loose sand or limestone track it's going to need taller tires with deeper tread.
The torque curve on a two stroke diesel is always at peak rather than peaked at mid rpms like a fourstroke. The fourstrokes is able pump more air per revolution when lugged down to about 1/2 to 2/3 of it's rated HP rpms. If geared too high she's going to bog down.
A two valve 2-53 might make 50HP at 2400rpms with N50 injectors and converting the oilbath aircleaner to a dry filter. The other manufactures have tractors in that weight range that can be easily souped to 75+ HP Better swap the stock rods for those that spray cool the pistons when injectores are up sized from the S35's.
Vic
02-05-2008 18:09:09
 Re: 435 JD in reply to buickanddeere, 02-03-2008 06:22:23
thanks for the comeback I have a set of 16.9 X 38 But now I think I will stick to the 15.5 X 38 or 18.4 X 28 I have 115 Inj and a big blower
