Breaking hubs on Massey 444 !!!!!!!!!!!!!
Rick Kaiser
06-16-2002 08:09:42
I am pulling a Massey 444 and have broken 4 hubs. The first was an origional 444 hub. Then changed axles to 44 and broke 2 more massey hubs. Tryed a oliver 70 hub with U-Bolts and broke that to. Does anyone have a solution?????
don
06-19-2002 14:02:14
 Re: Breaking hubs on Massey 444 !!!!!!!!!!!!! in reply to Rick Kaiser, 06-16-2002 08:09:42
You have to keep the hubs TIGHT!!!after you move them, put a wrench on them after each hook
kspuller
06-18-2002 14:57:28
Just wondering what size tires and weight classes you run. I've pulled my 44 for 30 years have have not (knock on wood) broken a hub and nobody else I know have either. 4500-5000-5500# with 15.5 or 14.9x 38"
Rick K
06-18-2002 18:44:36
 Re: Re: Breaking hubs on Massey 444 !!!!!!!!!!!!! in reply to kspuller, 06-18-2002 14:57:28
I am pulling in the 5500 and 6500 stock classes. Your hubs must be rusted on real tight or you are extremely lucky. The tires are 15.5 Firestone Field and road. Thank you
kspuller
06-19-2002 16:06:22
 Re: Re: Re: Breaking hubs on Massey 444 !!!!!!!!!!!!! in reply to Rick K, 06-18-2002 18:44:36
nope-I can side my hubs in and out--Ijust make sure the hubs bolts are tightened evenly and torque.
bigmotors
06-16-2002 11:10:02
Find a set of M & W hubs. Better made and lighter.
I've broken two Massey hubs pulling myself.
Rick Kaiser
06-16-2002 19:39:23
 Re: Re: Breaking hubs on Massey 444 !!!!!!!!!!!!! in reply to bigmotors, 06-16-2002 11:10:02
Any idea where I might find a set of M & W hubs?
Pete1468
06-16-2002 09:22:49
Have you tried weld on hubs? I have heard that Massey hubs have a problem with breaking.
Rick K
06-16-2002 19:40:49
 Re: Re: Breaking hubs on Massey 444 !!!!!!!!!!!!! in reply to Pete1468, 06-16-2002 09:22:49
Will welding on hubs weaken the axle?
Pete1468
06-17-2002 14:01:15
 Re: Re: Re: Breaking hubs on Massey 444 !!!!!!!!!!!!! in reply to Rick K, 06-16-2002 19:40:49
The only one I've seen break was one that was stick welded on. I've wire welded on all of mine and my friends they haven't broken yet.
