Flat Tire
5 Star General
02-04-2008 16:01:33
While sitting in line to pull my rear tire which is mounted on aluminum rims suddenly went flat. I found a 4 in. hole directly in the middle of the tube where the two halves would have come together. Wondering if anyone ever had that happen? Thanks to good friends I was able to find another tire. Even though it had to be mounted backwards, I was able to finish pulling.
JDH
02-06-2008 15:05:12
 Re: Flat Tire in reply to 5 Star General, 02-04-2008 16:01:33
General, I have a question about those wheels. Where did you drill the valve stem hole? I'm gonna try to mount mine tubeless this weekend, but I just don't know how the tube sits in that V. Approx. how far down from the bead should I put the stem just in case the tubeless idea don't work? Thanks!
5 Star General
02-07-2008 04:40:46
 Re: Flat Tire in reply to JDH, 02-06-2008 15:05:12
Mine were per drilled at four inches. Let me know how you make out going tubeless. Art
Tubeless?
02-05-2008 08:07:44
Maybe you'd better go that route Art, it would keep it from happening again to you in the future...
Captainhookerus
02-05-2008 07:53:50
Sound as if you had the General coming and going that last hook. Which side won? Maybe the Twister and I will have to try that.
Ken <{:-)
MCL
02-04-2008 19:31:50
I don't know you or your situation. A friend of mine owns a tire shop. He says he is having a lot of trouble getting good tubes any more. All foreign made crap.
LW
02-04-2008 20:00:14
 Re: Flat Tire in reply to MCL, 02-04-2008 19:31:50
We've had the same problem mainly with firestone tubes made in Venazuala(SP) there either cracked up or they pop holes as soon as you mount them. I sent a pair back and got a set of carlisle's made in china and have to say they were made like a tube was here 40yrs ago thick and heavy with brass nut and stainless valve cap. The rubber even looked better.
Jim Johnson
02-04-2008 18:47:10
I think you should get rid of those rims, you might even have to give them away but get rid of them now. I think you have my number, I"ll try and help you with that task.
Jim
Captainhookerus
02-05-2008 07:47:39
 Re: Flat Tire in reply to Jim Johnson, 02-04-2008 18:47:10
Hey Twister do you have any of those super light ones you could express to the General?
Jim Johnson
02-05-2008 18:45:37
 Re: Flat Tire in reply to Captainhookerus, 02-05-2008 07:47:39
Sure enough Captain, Mark just finished a set today. How much boot should Ol' Art have to pay ?
Jim
5 Star General
02-05-2008 15:42:52
Sweeper may have a point, could be the mud. HA! HA! One of the Farmall Pullers' called me today. He said throw the tubes away and put some good sealant around the rims, not to much just enough. I guess it makes quite a mess to clean up. I was waiting for Jim to go bananas when someone ask if anyone had weighed a firestone. Still 84 degrees.
jd b puller
02-05-2008 20:38:52
 Re: Flat Tire in reply to 5 Star General, 02-05-2008 15:42:52
General - You'd think for what those rims cost you could go tubeless...
Sweeper
02-05-2008 10:34:47
Might be that Mississippi gumbo ate a hole in the tube while at Tunica.
