ChadS
02-23-2008 05:16:42
Re: Farmall M and IH 560 in reply to casepuller22, 02-22-2008 21:13:49
IH M Puller said: (quoted from post at 22:13:49 02/22/08) Question... IF I were to diesel with my farmall M puller... what would be the easiest to bolt in and what would anyone recommend for the transmission? Also... if I were to buy an IH 460 or 560, what diesel could I put in there easiest. I have a little left over this year and I thought about maybe buying a burned out combine for its engine.. is this feasible?? |
Example, the IH 806. biggest engine you could get was a 361. same family as the 407,,, they put the C series blocks in the 806, and the 361 was in the 806,, so it would be easiest to use a 361-407 and not have to alter much on either the M or the 560. some go over that and go with the 414-436-466 family,,, you have to do some work, but they will fit,,, the 560 and the M have the exact same engine back plate bellhousing bolt pattern,,, only difference between the two are the bolt holes that bolt the plate to the block,,, clutch and flywheel,,,, if a 361 or a 407 was used,, use the flywheel from the 806 and like size tractors,,, may have to adapt the clutch disk splines up to match the rear end input shaft,,, but thats no big deal. Should be a matter of the tooth count on the starter ring,,, but Im sure it can be fixed up to work. ChadS ChadS3@hotmail.com
