Farmall M/400 Head
mhankc
02-25-2008 17:22:09
I have an M that I am putting a 400 head on. My question is, the 8060 head had the fittings at either end with the line attached that run from fitting to fitting under the valve cover, and then a line attached to the rear fitting and run out to the air filter. The 400 head has a short tube that sticks up in the front of the head and attaches to nothing under the valve cover. I assume it remains that way...is that correct???? I also drilled a hole in the top rear of the valve cover and attached the vent line there. Is that correct and am I all set, or do I need to do something more??? Thanks in advance for any help.
Puller1
02-26-2008 13:55:57
 Re: Farmall M/400 Head in reply to mhankc, 02-25-2008 17:22:09
You are good to go
