Marion NC
farmallflogger
06-21-2002 09:25:11
Anybody going to Marion NC for the OTTPA pull tomorrow? Is the starting time still 6PM? And would somebody have directions from I-77? Thanks!
SATPA PULLER
06-21-2002 19:45:17
 Re: Marion NC in reply to farmallflogger, 06-21-2002 09:25:11
ABOUT THE 460 @ STATESVILLE . YOU MEAN THEY STILL LET HIM DO THAT . THE LAST TIME I SAW HIM PULL, HE MUST HAVE SHIFTED 10 TIMES . PERSONALY I THINK THAT USE OF A T/A OR SIMULAR SHOULD BE ALLOWED IN THE STOCK CLASS . AFTER ALL THESE TRACTORS DID COME FROM THE FACTORY " STOCK" WITH THESE TRANSMISSIONS.SAY START ON LOW SIDE , THEN TO HIGH AND THEN DOWN AGAIN . NOT!! UP ,DOWN , UP ,DOWN ,UP ,DOWM AND SO ON . THE 460 PULLER IS STRETCHING THINGS A BIT. IF HE PULLED WITH SATPA SOME OF THE PULLERS WOULD HAVE A FIT . SOME ONLY WANT 1ST. GEAR IN STOCK CLASS . THEY WOULD REALY FLIP OUT IF THEY SAW THIS GUY PULL .I SAY THAT BECAUSE HE PROBABLY WOULD WIN. THE TIME I SAW HIM PULL ,I THINK HE DID. LOOKS LIKE ALL THAT SHIFTING WORKS FOR HIM . I THINK IF THE 460 WERE MINE I WOULD LEAVE THE T/A ALONE AND WORK UNDER THE HOOD A LITTLE. GOOD LUCK SATURDAY!!! I GOT TO WORK OR I WOULD BE THERE
ldr
06-21-2002 14:06:54
you need to go up hwy 74 to hwy 221 then go towards glenwood nc hope this helps
Agent Orange
06-22-2002 19:52:52
 Re: Re: Marion NC in reply to ldr, 06-21-2002 14:06:54
Good to see you in here. you shoould use "rmwsd" Went to the Richburg show today. We had quite a gathering.
