855 cummins pistons
jd plowboy
03-20-2008 17:55:12
does anyone have 4 good used 5 1/2 inch bore 855 cummins pistons for sale.
J Schwiebert
03-20-2008 18:08:05
 Re: 855 cummins pistons in reply to jd plowboy, 03-20-2008 17:55:12
Not to be a smart one but what do you have in mind? Reason I asked one time when I worked for the aftermaket we had 13 different 855 pistons.Do you know what Cummins CPL these pistons should be from?
jd plowboy
03-20-2008 18:44:50
 Re: 855 cummins pistons in reply to J Schwiebert, 03-20-2008 18:08:05
no i dont. was told they would work in a moline tractor with a 5 1/2 bore. was told the top would have to be cut off alittle to get compression around 10-1
willywonka2
03-20-2008 21:50:16
 Re: 855 cummins pistons in reply to jd plowboy, 03-20-2008 18:44:50
have tried this stunt before. not worth the time and effort. have to make wrist pin bushings and then find the compression height and mill off the top. after that the have to weld up whats left of the combustion bowl and re machine. alot of time envolved and if you cant do the machine work it could get expensive too. by the time you get all that done you could have had a custom piston made but if you still want to do this a natual piston will work better. Schwiebert is right.alot of different controlled parts listings
