Buda 262
MMOGTA
04-01-2008 15:13:26
If there are any gurus out there that could give some pointers on these engines, would like around 120hp. Please email, thanks.
ANON
04-02-2008 17:54:33
 Re: Buda 262 in reply to MMOGTA, 04-01-2008 15:13:26
I have seen the one posted before with 400 plus cubes.I understand ALOT of grinding for clearance in cam area. I was under the impression a 273 block with a 262 crank brings you to 336CID. Someone correct me if I was given the wrong info.
buda builderage
04-02-2008 21:32:16
 Re: Buda 262 in reply to ANON, 04-02-2008 17:54:33
If memory serves me correct the 262 motor is 3.5625" bore x 4.375" stroke. 273 is 3.75" bore x 4.125" stroke. So the 262 crank only gives you 1/4" more stroke, which should put the 273's cubes up to about 290.
ANON
04-03-2008 17:34:37
 Re: Buda 262 in reply to buda builderage, 04-02-2008 21:32:16
Thank you. I never sat down and figured it out with a calculator.
strokin
04-01-2008 18:32:53
id start with a farmall 1st you cant do a whole lot with a buda 262
JDGnut
04-01-2008 18:59:00
 Re: Buda 262 in reply to strokin, 04-01-2008 18:32:53
Gas or Diesel... We built a diesel.. Weren't happy with the HP... I'd build a gasser..
JDGnut
MMOGTA
04-02-2008 21:24:21
 Re: Buda 262 in reply to JDGnut, 04-01-2008 18:59:00
Gas
buda builderage
04-01-2008 20:08:31
There's not much room in there for big bore or stroke. 120hp would be the max if you can make it swing. They've got a lot of initial potential. A gas will go 90hp with just LP pistons. custom rods for clearance and a smaller journal will get you some stroke. I've heard 5.5" stroke and 4" bore (415 cubes), but it's hard to believe. The cam is already clearanced from the factory to clear the stroke.
