M-farmall hydraulics
randy
03-12-2002 17:58:28
can anyone help me,the hydraulics on my m-farmall will raise my 9 foot new holland haybine easily, but for some reason will not let it back down. my shop manual is no help.i would like to be able to cut hay with this tractor, and other hydraulic work. please try to keep response in simple terms that a dumb hillbilly can understand! thanks!
Keevin
03-17-2002 17:32:57
 Re: m-farmall hydraulics in reply to randy, 03-12-2002 17:58:28
on the right side of the tractor there is one fitting coming out of the pump . I beleive that is for single action cylinders . On the left, there is two fittings for double action cylinders. I think.
John S-B
03-18-2002 20:24:12
 Re: Re: m-farmall hydraulics in reply to Keevin, 03-17-2002 17:32:57
That's incorrect. The two front outlets are for single acting cylinders. The rear outlet on the left side is for using a delayed cylinder to raise the rear of an implement, ie;a tandem disk, after you raise the front.
Keevin
03-19-2002 08:57:19
 Re: Re: Re: m-farmall hydraulics in reply to John S-B, 03-18-2002 20:24:12
thanks for correcting me.
John S-B
03-19-2002 20:41:36
 Re: Re: Re: Re: m-farmall hydraulics in reply to Keevin, 03-19-2002 08:57:19
No prob. Keevin, That what everybody's here for.
Keevin
03-17-2002 17:31:17
John S-B
03-14-2002 21:53:38
Randy do you have a double or single acting hyd. system? If you have single acting system and a double acting cylinder you need a breather in the side of the cylinder that is not used so air can move in and out.
John S-B
03-14-2002 21:57:48
 Re: Re: m-farmall hydraulics in reply to John S-B, 03-14-2002 21:53:38
Randy I just realized that if that you needed a breather it won't lift well either. Maybe there's something clogging it ( if you have that type ). Are all your hoses connected right?
Chuck
03-14-2002 10:36:10
Check your hydraulic couplings to make sure they are all the same.Some have points and some have balls. If you have a point and a ball coupled together they don't always work.
