JD730lp PTO clutch
Scott Hazlewood
06-22-2002 11:31:01
Looking for the trick to reinstalling the pto clutch disks back into the clutch housing with the housing still in the back of the tractor. There are three clips that hold a plate, which is part of the throw out/clutch assembly, to the pto rear cover. It appears I must assembly the clutch and install the clips before putting the clutch assembly into the clutch housing that is inside the tractor. Does the clutch housing come out? Or how do you obtain access to line up the friction plates into the housing while installing clutch and rear cover at the same time? Help is needed. Thanks
