MF Repalce rings and sleeves??
Matt
11-08-2001 05:05:38
I have a MF 95 (MM GBD) and was wondering how to check/test the condition of the rings, sleeves look ok, no visible gouging or scratches, now that I have it apart do you figure I ought to just go ahead and replace the sleeves and rings? Any advice would be appreciated.
Tyler(WA)
11-08-2001 08:30:30
 Re: MF Repalce rings and sleeves?? in reply to Matt, 11-08-2001 05:05:38
Best way to check ring ware is with a compression check before you break it down. However, once you pull the head, look for a ridge at the top, where the rings stop their upward travel. If there isn't a visable ridge and there are no blemishes to the cylinder walls, you don't have to replace the sleeves.
Run the pistons up to the top of each cylinder and look at the ring gap. If you can't see the rings, you may have to pull the pistons, dismount the top ring and put it back in the cylinder without the piston. Be sure to look all the rings over for any broken or cracked rings. Measure the ring gap with a feeler gage with the ring oriented like it would be if the piston were there. The rings should have between .007" to .015" clearance (someone correct me here if my memory isn't right.) More than that shows ring ware and you would do good to change them.
Many tracors have been rebuilt without new sleeves. They work fine and go the miles.
