Locking pins on three point hitch
Orville Lonnema
02-23-2003 19:06:19
1964 John Deere 3020 gas: How do you replace the locking pins that you use when you extend the arms of the two lower links of the three point hitch on this tractor.
Thank You
JMS/MN
02-26-2003 22:34:22
 Re: Locking pins on three point hitch in reply to Orville Lonneman, 02-23-2003 19:06:19
Are they broken, rounded off to where they don't hold? Top of the tube they are in is welded on, should be a spring underneath the top. If the rod is bad, you can only cut the tube open and replace it. Check with the parts book.
