JD630 crankshaft side play
Roger
01-09-2002 19:47:04
Would someone please tell me how to take out the sideways play? Is it OK to just move the flywheel in untill most of the play is gone? Thanks for the help.
Gene Davis
01-11-2002 21:37:57
 Re: JD630 crankshaft side play in reply to Roger , 01-09-2002 19:47:04
The engine should be stopped, then lock the brakes (so it doesn't roll over your feet), put the trans in neutral, engage and disengage the clutch lever and watch the flywheel side to side movement, this movement is your end play, don't remember the exact amount, but it is a very small amount.Too much end play will cause a thumping sound almost like a main bearing sound, and may cause main bearing problems from the side to side hammering on them. Gene Davis
Matt B
01-10-2002 08:58:09
Yes, the crank shaft end (side) play is controlled by the flywheel position. Check the condition of your flywheel and crank splines that they are not worn.
MB
Jerry S
01-10-2002 10:32:35
 Re: Re: JD630 crankshaft side play in reply to Matt B, 01-10-2002 08:58:09
Matt is right. There is supposed to be a certain amount of gap there so you don't ruin your gasket from the flywheel being too tight against the main case. Usually you can tell your flywheel is not in far enough because your engine will knock and sound like it is coming from the clutch.
