Tractor Talk Discussion Forum
3 point backhoe for MF TO35
Dan from BC
06-13-2007 22:06:49
As I live In the mountains there is not allot of farmland around and therefore no selection in used 3 point backhoes. My nearest largest city is Sokane Washington. I live about 3 hours North. Does anybody know of a place around this area that migh have some used backhoes? Is it really better to have a frame mount? Is there a good website where I can find more info on the different makes of 3 point backhoes?
Dan From BC
06-14-2007 23:07:51
 Re: 3 point backhoe for MF TO35 in reply to Dan from BC, 06-13-2007 22:06:49
Thanks for all the replies , I'll keep looking.
David Snipes
06-14-2007 11:27:42
I live in Spokane and I rarely see them for sale used. I have a frame mount Bradco backhoe built by American Trencher. It has its own hydraulic pump driven off of the PTO. Basically it has been a good machine except for the swing mechanism. The next time you cross the border pick up our local classified ad free paper, the Exchange or the Nickel Nick
Gerald J.
06-14-2007 08:28:34
I have a Long 1099 that I've used on my MF-135 with a MF-236 loader. I used the loader's external hydraulics rather than the little tractor pump.
A frame mount would be best, but after I looped a sturdy chain from the lower 3 point pins under the tractor drawbar mount, the back hoe could lift the tractor and had good digging power.
I now have that loader on my JD-4020 and also put the back hoe on there using the tractor's internal hydraulics.
Where to find one, I don't know, I bought my Long at Carbon Iowa and had to do a lot of rebuilding, some immediately some later as previously made cobbles crumbled.
Gerald J.
bent1
06-14-2007 06:27:29
I have a 3 point backhoe mounted to a MF 35 Special with a manual trip bucket on front. It does an excellent job digging and trenching. It had a digging depth of 7 ft. You could check ebay for different models.
2x4
06-13-2007 22:44:29
hope you dont have much digging to do cause even if you get something rigged up its not gonna do much. You might wanta consider renting.
