Tractor Talk Discussion Forum
More on my WD-9
maestro
06-17-2007 18:28:04
The number one cylinder, or the cylinder that the injector isn"t fire all the time has a compression blow when I do what you suggested. I checked the others and they are OK. Now what would you suggest. I know on my super WD-6 I had some issues with the starter valves but when I took off the valve cover and hit them with a hammer and a piece of Oak board they began to work fine. Can one tighten the valve on that cylinder to help it fire. When it ran on the diesel side today it acted like it was firing some of the time. I let it run for some time and the longer it ran the better it seemed to get. Any more suggestions would be great. This is helping a great deal. Thanks, maestro
RAB
06-17-2007 22:58:18
 Re: More on my WD-9 in reply to maestro, 06-17-2007 18:28:04
Any bubbles in the radiator when running? If not, may not be a crack which is a good start. Check out the change-over mechanism? If clearances are good, it seems like the internals need checking out. Contined running with a leaking valve will likely just make things worse.
Regards, RAB
