Tractor Talk Discussion Forum
any good stop leak products???
rod
09-02-2003 18:02:42
Has anyone found a good stop leak product or are they all just a waste of money this old machine leaks from every seal both hyd and engine oil if you know of a product that works lets hear it.
regards
rod
Anthony
09-13-2003 20:21:16
 Re: any good stop leak products??? in reply to rod, 09-02-2003 18:02:42
Bars' leak used to claim tht their leak stopper was successfully used on a nuclear submarine in the 50s, i have also used course ground black pepper.
rod
09-03-2003 07:15:27
I was looking on the net some things claim to swell up dried out seals by softening the rubber.
regards
rod
john
09-03-2003 08:37:49
 Re: Re: any good stop leak products??? in reply to rod, 09-03-2003 07:15:27
yes but like I said it is only teporary
dhermesc
09-03-2003 08:53:41
 Re: Re: Re: any good stop leak products??? in reply to john, 09-03-2003 08:37:49
Actually the "soft seals" theory works to a point, will it stop a leak, usually not unless your very lucky. But I make it a point of adding stop leaks at alternating oil changes (engine and trannys) to prevent seals from getting hard in the first place. I have also been told by mechanics that engine flushes are extremely hard on seals (the solvents dry the seals out) and recomend using a additive with the oil after a flush.
JOHN
09-03-2003 09:05:04
 Re: Re: Re: Re: any good stop leak products??? in reply to dhermesc, 09-03-2003 08:53:41
i will agree with this 100% but preventing seals from getting hard and dry rotten is one thing. fixing a seal after it is allready cracked is another.
Tom
09-03-2003 05:55:09
Years ago I tried all the different stop leaks in the radiator. EVERY ONE of them will lead to more trouble, less efficient coolingt, over heated engine, down the road. If you have used one, then you need to pull the radiator and take to professional radiator shop for boil-out or rod-out. Don't waste your time and money on "snake oil" quick fixes. Repair things properly. My $0.02.
Randy
09-03-2003 05:17:36
I don't know of anything that stops leaks in the engine or hydralics, but for the radiator any Bars stop leak products work well. I think the pressure is to great on hydralics for any kind of stop leak to work.
Indydirtfarmer
09-03-2003 03:57:30
Right up front; I don't like the stuff! It doesn't matter to me if it's the radiator, the engine or the hydraulics, I don't think they are designed to have "stuff" that clogs up holes, poured into them. Sometimes, you have to do, what you have to do. I've used radiator stopleak to get home or out of the field before. The thing is, you're masking a serious problem, instead of fixing it. The few times I've ever used radiator stopleak, it was Barr's original. As far as engine and hydraulic "sealers", never used them, don't know the first thing about them.
john
09-02-2003 19:39:05
my personal opinion is that seal stop leak is just a put off repair. yes they have there place a quick fix to get you through the summer or such. since you say every seal hyd. and engine is leaking it sounds like it is past that and is repair time. seals like anything do not last for ever.they either wear out from use or dry rot from no oil on them in non use.I do not have any prefance for one brand over the other.(do not feel bad I have seen people mix 90w oil in there engine oil to stop smoking and leaks)
Eric Hosette
09-02-2003 19:52:01
 Re: Re: any good stop leak products??? in reply to john, 09-02-2003 19:39:05
I dont know much about engine oil or any seals but for radiator repair I have always found that long cut chewing tobacco works great. It plugs most major holes until the radiator is drained and then the tobacco falls out with the coolant.
