Tractor Talk Discussion Forum
Draft/position control adjustment-Kubota
P Wog in midwes
10-04-2003 17:56:11
Anyone have draft/position control adjusting experience?
I have a newer 40 HP Kubota that I ordered a draft control kit for. Installation went fine.
Adjusting is different because the translation to english is not good. To adjust position control it says to "adjust rod so relief valve does not work when set position control to highest level". It doesn't say if it should be running or not. Does this mean the 3 pt lift arms do not rise? If so, should they have weight on it? Should it even be running?
I started my 80HP JD with draft control off and 500 lbs on and the 3 pt Pt lifts but seems weak. Anyone have experience with this?
Jamie
10-06-2003 21:10:42
 Re: Draft/position control adjustment-Kubota in reply to P Wog in midwest, 10-04-2003 17:56:11
TO adjust position control start tractor and raise the positon control lever up all the way(draft control lever up also)(you should not have anything hooked to 3 point).If the relief valve comes on when the 3point gets to the top then you need to adjust rod. (you will hear relief valve come on).Basically all you are doing is adjusting
the hieght at which the 3 point will stop coming up. If it goes up too high then internal damage can happen so the relief comes on to stop hyd fluid from pushing 3point any farther.
