Tractor Talk Discussion Forum
Winch on Lawn Tractor
Ian Spare
10-06-2003 13:23:37
Can you put a small electric winch on a sears lawn tractor? maby a atv winch? If so how ? Thank you very much !
- 1999 Lawn tractor
- 16.5 Kohler
- 30 amp battery (can dump-it if need stronger one!)
Nolan
10-07-2003 10:27:08
 Re: Winch on Lawn Tractor in reply to Ian Spare, 10-06-2003 13:23:37
You might want to check out the portable 12v electric winch Harbor Freight carries. They work remarkably well. You can bolt it up to the riding mower / lawn tractor if you wish, or use the rear hook to grab the tractor.
I got one of these for my 2wd truck because I was tired of getting constantly stuck. It works quite well. No, it's never going to lift my truck up a cliff, but it certainly does the job of pulling me out of muddy fields and such.
ray
10-07-2003 07:06:09
That tractor is pretty light - I don't see why you could not put a winch on it though. I'd think the tractor start moving torwards your "winch load" before the winch reached peak current draw.
I have a vision of the craftsman getting catapaulted after the wheel blocks slip. lol.
cliff
10-06-2003 20:12:12
It really should not be all that much trouble. Most riding mowers have a flat frame in the front near the front wheels. Many times this will be where a small bumper can be bolted on. On ebay I have seen some good deals on atv winches.
I can see where it would come in handy to pull something like a large limb off a fence.
However as the other guy mentioned, be sure the frame can stand up to the extra pull you will pulling against it.
Tex
10-06-2003 20:09:07
Jack, how would you mount the wings ? Hmmm got me thinking now
Jack McGann
10-06-2003 16:15:03
Not sure I want to ask why, but I suppose a winch makes more sense than wings and a propeller...
Are you getting the tractor stuck and need to pull yourself free or are you trying to pull something with the tractor?
Biggest problem you'll have is finding something strong enough on the tractor to bolt the winch to. Most tractors like that are made of pretty flimsy metal. Also, battery and charging circuit aren't nearly big enough. You'll need something in the range of a couple of hundred amps if you plan to use the winch much at all. Not only will you need a bigger battery, you'll need a bigger alternator to keep it charged. Could get a bit pricy. Ever consider a hand crank (boat type) winch or a come-along?
Ludwig
10-07-2003 06:37:48
 Re: Re: Winch on Lawn Tractor in reply to Jack McGann, 10-06-2003 16:15:03
Uhh Jack, its a lawn tractor...
A 1000# winch isn't going to need a "couple of hundred amps" and he isn't going to ever need more than a 1000# winch because of how little a lawn tractor weighs.
Dana
10-07-2003 07:50:08
 Re: Re: Re: Winch on Lawn Tractor in reply to Ludwig, 10-07-2003 06:37:48
Comeon folks. It's a lawn mower. Just get off & push.
big fred
10-07-2003 11:12:55
 Re: Re: Re: Re: Winch on Lawn Tractor in reply to Dana, 10-07-2003 07:50:08
As soon as he gets off, the engine is gonna quit. Okay, you can get off, hold the seat down with your hand to defeat the interlock and push with the other hand. That works pretty good. But, it's dang near impossible for a one-armed man.
Dana
10-07-2003 11:26:18
 Re: Re: Re: Re: Re: Winch on Lawn Tractor in reply to big fred, 10-07-2003 11:12:55
Have to get off anyway to hook up the winch cable wouldn't ya?
big fred
10-07-2003 14:41:05
 Re: Re: Re: Re: Re: Re: Winch on Lawn Tractor in reply to Dana, 10-07-2003 11:26:18
Yup, but ya get a big enough winch it won't matter if the motor's runnin', least not until yer battery's dead. Ain't no easy answer to this man's dilemma. ;o)
