Tractor Talk Discussion Forum
3020 JD
Ken
10-08-2003 14:52:05
I have a hydraulic leak in my steering unit under the cowl. What's involved in removing the unit.
Dan
10-08-2003 18:49:54
 Re: 3020 JD in reply to Ken, 10-08-2003 14:52:05
are you sure you need to remove it? could leak maybe an o ring on one of the fittings or perhaps just a loose fitting. I would check that first and of course will be easier to locate when still hooked to tractor power.
twopop
10-08-2003 16:16:50
remove the cowl,remove the steering wheel.remove the dash.unhook throttle linkage under dash.disconnect hydraulic lines.remove two 1/2 inch bolts.remove steering valve.
