Tractor Talk Discussion Forum
What's wrong with this picture?
Allan
10-20-2003 05:39:31
third party image
Hi All,
I just bought this '51 tractor a few days ago. Is there anything about this guy that looks wrong to you as it does to me?
Allan
Ultradog MN
10-20-2003 17:41:53
 Re: What's wrong with this picture? in reply to Allan, 10-20-2003 05:39:31
Real good looking H Allan.
Wouldn't mind owning one myself someday.
Only thing I can see wrong with that tractor is it's a little too pretty.
You need to hook a plow up to it and get them wheels and weights muddied up a little then no one will notice if they're not quite correct.
Happy tractoring
Jerry
JMS/MN
10-21-2003 01:07:52
 Re: Re: What's wrong with this picture? in reply to Ultradog MN, 10-20-2003 17:41:53
Hey, Jere- give me a shout- my msgs to you don't go through.
Jim.UT
10-20-2003 10:26:27
The main thing wrong with that picture is that my house should be in the background!
sammy the RED
10-20-2003 08:03:32
Muffler, tires and wheel weights.
mike-nm
10-20-2003 07:58:48
The wheel weights are the kind used on the old F-20 round spoke wheels, maybe others too like F-30, but I have had F-20's that had them.
Allan
10-20-2003 08:01:38
 Re: Re: What's wrong with this picture? in reply to mike-nm, 10-20-2003 07:58:48
Hi Mike,
Okay, they are mounted correctly then? What do they weigh per weight, got any idea?
Thanks,
Allan
Loren from MN
10-21-2003 14:25:05
 Re: Re: Re: What's wrong with this picture? in reply to Allan, 10-20-2003 08:01:38
Pat is correct. They are F & H weights. I believe they run about 125 lbs. They were used on a number of early spoke wheels tractors. John Deere used them all the way through the styled letter series, and Allis through the WD series. I think MM used them too. I've got a set on my JD 60, drilled out to fit the 3 hole weight bolt pattern.
pat
10-20-2003 07:42:33
They look like F&H wheel weights.
Paul J
10-20-2003 05:54:15
I don't know if you can call it wrong or not, but the wheel weights are not IH row crop. They may be for one of the standard series. If they work, what the hay, they'll do.
rustyfarmall
10-20-2003 07:01:21
 Re: Re: What's wrong with this picture? in reply to Paul J, 10-20-2003 05:54:15
The wheel weights are the only thing I can see that might not be correct.
Allan
10-20-2003 06:15:20
Hi Paul,
Is that what it is? I thought they were mounted backwards...but then again, they don't have the squarish centers so you're probably right.
It's got two sets of 'em and yes, makes no difference in the larger scheme of things, I guess.
Allan
