Tractor Talk Discussion Forum
No power steering on JD 2840
Tom
10-20-2003 19:18:12
I am working on a JD 2840 that looses the power steering when the pto is running. Any advice or where to start? Thanks
twopop
10-20-2003 20:47:14
 Re: No power steering on JD 2840 in reply to Tom, 10-20-2003 19:18:12
you need a shop manual.your pto clutch piston is probably leaking and using all the oil from the trans pump.then there would be short supply to the main pump.
cannonball
10-21-2003 05:06:05
 Re: Re: No power steering on JD 2840 in reply to twopop, 10-20-2003 20:47:14
twopop is right ..does your hi low work...could be both leaking and transmission pump could not keep up...
Tom
10-21-2003 19:22:58
 Re: Re: Re: No power steering on JD 2840 in reply to cannonball, 10-21-2003 05:06:05
I don't know about the high low-hadn't thought to check it. Thanks for the advice
