Tractor Talk Discussion Forum
806 IH aDon't move
grazer
11-04-2003 05:45:24
We have an 806D that when the weather gets colder the clutch and the power steering does not work. Sometime after letting it run for awhile with the pto running it works like normal but other time it does not do any good. We have changed all the oils thinking it might be a water problem but it does not help.Do not know if it makes any dif but when it does not work the 2 point and rear hydolics work just fine.
Ron 1456
11-04-2003 10:34:21
 Re: 806 IH aDon't move in reply to grazer, 11-04-2003 05:45:24
The hydraulic pump (not the hitch pump) has lost it's prime. Used to have trouble with my 806 when it was extremely cold. We would remove a plug on the back side MCV plate on the left side of the tractor. Then start the tractor for just a second or two and then shut off. Some oil will spray out but the pump will be reprimed. There is a spring behind the plug so it can sometimes be a little work to get it back in. This problem only occurred a few times when it wa near 15 below 0. You may have a bad O-ring somewhere if this happens very often. By the way there are two plug on the back of the plate. It such be the larger(top)one.
