Tractor Talk Discussion Forum
bore and stroking 1948 john deere model b.
leon
12-05-2003 16:22:39
has any one out there ever bored and stroked a
a john deere model b engine. if so, what parts were used and how did it work out? i am interested in doing this for the tractor pulls. i would like to know the parts suppliers, how they can be contacted and ball park figure on the cost...if you know. any help, greatly appreciated. thanks.
Chris-se-ILL
12-08-2003 10:13:30
 Re: bore and stroking 1948 john deere model b. in reply to leon , 12-05-2003 16:22:39
Boring the cylinders will not give you "that much" power (volumetric) increase! And, stroking will most likely weaken the crank (No, stroking is not the same as grinding .060 undersize, which does not weaken the crank).
There are things that I have helped do to JD "G" engines for the purpose of increasing horsepower in antique pulling tractors... but I do not know if the same things are applicable to the JD "B"! Such things as... increasing compression by doming (adding material to) the pistons (if they are aluminum pistons); increasing valve head diameters, while modifying the seats and ports behind the valves (thus increasing air flow), cylinder boring the common intake throat of the head to a larger diameter, matching and modifying the intake/exhaust manifolds.... things that are experimental but proven to work.
Brad Rostron
10-01-2005 13:06:43
 Re: Re: bore and stroking 1948 john deere model b. in reply to Chris-se-ILL, 12-08-2003 10:13:30
where can I get an exhaust manifold for my model B .... CHEAP?
Ron
12-05-2003 16:40:13
If you really need that much power increase in a "B"..get a Power Block..!! NOT a Stroker..!! You can only get the "B" Head to flow so much air and if you stroke it, it will only make Power at a lower RPM because of it... The 5" Power Block will make a Large difference.!
And will take the breathing to the LIMIT...!! The Design of a "B" is built around the rated RPM, and if that is changed (RPM Lowered), then the flywheel weight will have to be re-calculated to get the best out of it (NOT Balance, Inertia). I imagine "B" axles are getting expensive now..?? Get some, you will be breaking a few...!!
