Tractor Talk Discussion Forum
Case SC
Jeff
01-26-2004 05:41:58
I just a purchased a wonderfully running, 1955 Case Sc. The only problem I have is keeping the front end on the ground when I climb the least small hill. Does Case make front weights to rectify the problem, or does anyone have sugestions? Thanks for your time! Jeff
bill
01-26-2004 09:05:29
 Re: Case SC in reply to Jeff, 01-26-2004 05:41:58
I think I still have one of the nose weights for under he radiator If I can find it it would be for sale
capt kirk
01-26-2004 08:19:30
jal is right .mine has both of these and no problem like one you mention
jal-SD
01-26-2004 07:13:24
Don't think its a '55, last model SC's were made in '54. If the serial number begins w/80, its a '53 or '54. Any other #, subtract 4 from the first two #'s (ie: if the 1st 2#'s are 55-then if you subtract 4, its a '51) to get the year. Yes, Case did make a front end weight. Its about 100 lbs & fits under the radiator. You can get it in & out w/hay hook, but its TOUGH to do without hurting the radiator. Case also made cast iron wheels for the SC-they must weigh at least 75lbs each, maybe even more. (My $0.02 worth. jal-SD)
