Tractor Talk Discussion Forum
Woods Mower
Matt
02-05-2004 14:30:55
I found a 48" woods mower for a good price and purchased it thinking I could modify it to run as a belly mower for my Super A. It does a fair job but I have to go abnormally slow to get a good cut. I'm thinking my blade speed is too low- anyone know the typical blade speed in rpm for a 48" 3 blade woods rotary mower?
smurph72
02-07-2004 06:44:38
 Re: Woods Mower in reply to Matt, 02-05-2004 14:30:55
Was the mower from a Cub? A Cub turns backwards from a normal PTO. I have a Cub and 100. Wanted to move the Woods belly mower from the Cub to 100. Found out I'd need new blades AND new pulleys for tractor and mower due to different PTO speeds and direction. Project still incomplete.
Hope this helps.
dcm
Dave, Sherburne, NY
02-05-2004 19:35:40
I have the woods L59 they claim 120 mph blade tip speed. Once I ordered blades, it has three, and the first and second set were sharpened on the wrong side. The third set were right. Apparently they make blades to turn clockwise, or counter-clockwise. CHECK and see if yours are turning the right way. My L59 cuts great.
TimV
02-05-2004 19:07:46
Matt: I've got a 5-footer on my Cub, and though I don't have any firm numbers for you, I will say that the blades turn VERY fast--the first time I fired it up, I thought the whole tractor was going to take off and fly away! Mine is also a 3-blade setup, though I'm not sure of the brand--any identifying marks were long gone when I got the mower.
Russ
02-05-2004 18:38:50
No one answerd your question yet, did they! I would compare blade tip speed ( in feet per minute) with a mower that works well. then maybe you could increase the diameter of the pulley on the tractor. a three blade 48" has to turn quite fast because the blades are so short. A push mower with a 21" blade turning 3600 rpm would be 19,782 fpm! A 17" blade ( which is aproximatly what you have) would have to turn 4447 rpm for the same tip speed. I dont think you have to turn it this fast, but it gives you the idea.
tiny
02-05-2004 14:38:06
I run a 5ft finnish mower on my A and will mow in 2nd gear out back mow first gear up front and have no trouble. It is a old three point mower converted to a trailer type.
goofus fr L.A.
02-05-2004 16:01:28
 Re: Re: Woods Mower in reply to tiny, 02-05-2004 14:38:06
Those woods mowers always turned too slow, for a decent cut. Won't cut behaeer grass at all. I sold mine and just let my mother n law cut it all, with a sling blade. Keeps her out of the house in the summer. goof
Keith
02-05-2004 21:47:38
 Re: Re: Re: Woods Mower in reply to goofus fr L.A., 02-05-2004 16:01:28
Hey Goofus, I can relate to the grass cutting, when I was young and foolish, was stationed at Ft Cambell,Ky with the 101 st Airborne Div. made my Platoon Sarg. and had to cut grass with my mess kit knife..... Oh those fond memories.....
goofus fr L.A.
02-06-2004 18:55:25
 Re: Re: Re: Re: Woods Mower in reply to Keith, 02-05-2004 21:47:38
Keith, I may have seen you up there. I use to haul freight by Ft Campbell six times a week, going to Chicago, from Nashville, three trips a week. goof
mistake;
02-05-2004 21:50:18
should Have been "made my platoon Sarg. mad"
