Tractor Talk Discussion Forum
More Genius at the Helm
Mark
02-06-2004 09:42:39
I have a '62 blue Ford 4000 GAS and a '64 blue Ford 2000 DIESEL. Need I say more?
I bought the diesel tractor before I bought the gas. To differentiate red GAS cans from red DIESEL cans, I sprayed a spot of Ford blue on the diesel cans (like in Ford blue)so that I would remember that it went into the blue tractor.
The fuel filler is in the center of the hood over the engine and I had a 5 gallon can of "fuel" sitting up there draining. After it was about half empty I realized that even though the tractor was blue, the hood was WHITE. Ford, in those days distinguished the 4000 from the 2000 by a decal and a WHITE HOOD. The can had BLUE paint squirted on it..... ..... ..... ..... ..... .....
I got it out and after awhile things returned to normal, but had it been the other way, don't know what would have been the outcome.
I sure felt stupid!
Bob M
02-07-2004 11:15:07
 Re: More Genius at the Helm in reply to Mark, 02-06-2004 09:42:39
One of my kid's college roommates worked a couple weekends for us pulling wagons with my Super H at the Christmas tree farm. He was instructed to stop at the shop pump and fill the gas tank before beginning work on Sunday AM (he'd run the tractor most of the day before). Remarked on arrival to the field that the Super H sure doesn't use much gas - it took less than a half gallon to refill it.
Upon quizzing by my son we discovered he'd put the gas into the radiator! We spent the next hour draining, flushing and refilling the cooling system.
Apparently no harm was done - though several years later you still get a slight gasoline smell when you remove the rad cap.
Rusty Jones
02-09-2004 17:54:07
 Re: Re: More Genius at the Helm in reply to Bob M, 02-07-2004 11:15:07
I'd say about the guy who filled the radiator with gasoline--He probably couldn't pour water out of a boot, if the directions were printed on the heel! Sort of related to a box of rocks! Rusty J.
Bill
02-06-2004 11:12:52
If you mean what would have happened had you poured gasoline into a diesel I suggest you click on to Steve Carver's website. He explains and it was surprising to me. I will say no more as I don't want to open another hornet's nest.
Mark
02-08-2004 06:35:34
 Re: Re: More Genius at the Helm in reply to Bill, 02-06-2004 11:12:52
I looked herein and found nothing, the searched www for Steve Carver, and finally Carver equipment, in North Carolina.
Could you help me find the site to which you refer?
Thanks,
Mark
Bill (Wis)
02-08-2004 07:21:46
 Re: Re: Re: More Genius at the Helm in reply to Mark, 02-08-2004 06:35:34
Mark: I apologize profusely. Steve has changed his website and the remarks I referred to are no longer posted. What he said, basically, was that he had never seen any damage done to a Kubota diesel engine by accidentally running gasoline through it. I guess you would have to call them to verify. It is Carver Equipment in NC.
Mark
02-08-2004 16:36:05
 Re: Re: Re: Re: More Genius at the Helm in reply to Bill (Wis), 02-08-2004 07:21:46
Thank you sir for your followup.
Bill
02-09-2004 19:57:31
 Re: Re: Re: Re: Re: More Genius at the Helm in reply to Mark, 02-08-2004 16:36:05
Mark: I don't know how interested you are in the subject but I found pretty much the same info on TractorSmart.com in their technical info section. Regards: Bill.
sammy the RED
02-06-2004 10:32:58
Red Cans = Gasoline
Yellow Cans = Diesel
Blue Cans = Kerosene
JMS/MN
02-07-2004 12:17:38
 Re: Re: More Genius at the Helm in reply to sammy the RED, 02-06-2004 10:32:58
The conventional color scheme used by fuel stations, dealers, and farmers is Red for Gas, Green for Diesel. Fuel caps should be labeled. Gas in a diesel tractor burns well, fast, hot. Neighbor's dealer filled the diesel fuel barrel with gas by mistake, ended up paying for the engine rebuild.
Les...fortunate
02-07-2004 06:42:46
I have an assortment of gas and oil cans kicking around my shed. No diesel..... yet. I have taken an indelible marker and labeled what each one is for: straight gas, chain saw mix, etc. It's not so much for my benefit as for the next genius that comes along when I'm not around and "needs something". It ain't fool proof and I'll probably prove it someday. ";&)
