Tractor Talk Discussion Forum
6v battery cables
J
03-18-2004 10:36:10
What gauge battery cables do I need for a 6v battery for a Ford 600? The motor turns very slowly (eventually starts) and someone told me it was because the cables were too thin. I'm thinking they need to be 2 gauge. Any ideas?
Jerry/MT
03-19-2004 21:44:38
 Re: 6v battery cables in reply to J, 03-18-2004 10:36:10
Since your 6 volt starter takes twice the current of a 12 volt starter your 6 V power lead should be at least twice the cross sectional area of a 12V Lead. 00 is probably about right.
john
03-18-2004 23:51:38
Change it over to 12 volt
J
03-18-2004 16:15:17
Thanks guys.
acorange
03-18-2004 15:11:30
Use at least 1/0 cables. My experience with
WC/WD's makes them turnover much faster.
Jim.UT
03-18-2004 12:46:49
1. Yes your battery cables should be fatter than ordinary car battery cables.
2. Yes all your connections should be "clean, bright and tight".
Still, even with all that, your tractor starter is not going to spin as fast as your Dodge truck. Just the nature of 6 volt systems. The fact that it spins slower than what you're probably used to with your automobiles doesn't necessarily mean there's a problem. If you've taken care of items 1 and 2 above, and it still seems to spin slow, but it still starts then I'd say there's no problem.
RAB
03-18-2004 12:12:01
If they were original, they should be OK size-wise. You may find you have some corroded connection(s)which are causing this. Everything needs to be in good order with the 6 volt system.
An easy check would be to run jump leads to and from the battery and starter circuits and check out if voltage drop is same or less when operating starter. Like, if starter turns quicker, there may be a problem in the connecting wires. If it makes no difference, it may be a lazy starter, assuming battery is up to the job. You can also check this with another 6 volt jump battery and the jump leads. Just be careful with jump lead connections around batteries as any spark can cause a battery to explode!
Be safe and regards, RAB
buickanddeere
03-18-2004 12:02:50
Take your new 2/00 welding cables to an electrical contractor. They have a hydraulic compression tool to swag HD ends onto the cables. Run the ground wire direct from the battery to the starter motor case. Many 6V systems don't get fully charged. Set the voltage regulator up to 7.2V measured at the battery terminals while running at fast idle.
Polish Mike
03-18-2004 11:59:21
Double 'ought (OO) will be just what you're looking for on a 6 volt system. Make sure all your connections are "Clean, bright, and tight".
A 6 volt starter is always gonna sound like it's turning over slow, because you're so used to hearing modern starters turning over so fast. But invest in big cable, new terminals, and shine & tighten all your connections, and you'll be in great shape.
Craig
03-18-2004 14:52:20
 Re: Re: 6v battery cables in reply to Polish Mike, 03-18-2004 11:59:21
your problem might have nothing to do with the starting system. have you replaced the spark plugs and cleaned the carburetor? if your not getting good fuel or spark, it won't start no matter how fast it turns over. my Case, with its 12 year old battery barely turns over. however it always starts right away.
