Tractor Talk Discussion Forum
Ford 2000 diesel 1973 maintenance question
Chris Tobin
04-06-2004 05:00:52
I have a Ford 2000 tractor without a service manual and wanted to change the oil filter but I was having trouble locating the filter. Also need a new battery, I had to jumpstart it last week. Does anybody know if it takes a 6 or 12 volt
RWK in WI
04-06-2004 05:59:40
 Re: Ford 2000 diesel 1973 maintenance question in reply to Chris Tobin, 04-06-2004 05:00:52
For most practicle purposes it is safe to figure all FORD DIESELS were 12 volt negative ground. Since you say it is a 73 model it would be a 3 cylinder model - I believe the engine oil filter is a spin on located left side of the block about half way back below the center line - behind the radius rod.
Chris Tobin
04-06-2004 19:59:07
 Re: Re: Ford 2000 diesel 1973 maintenance question in reply to RWK in WI, 04-06-2004 05:59:40
Thanks for the info. Being in NC I neglected to do much winterizing and the battery lost its charge. It did start after using some cables to a car battery but would not hold a charge
Chris
