Tractor Talk Discussion Forum
Sleeve liner for 2010
papafoutz
04-19-2004 14:16:05
My father in law has a 2010 that needs a overhaul and my brother in law says you can't get the sleeve liner any more. So I check with my John Deere in my area and he said it doesn't say it is obsolete. But his compter doesn't show any body having it. Do you know if you can still get them. Part number is AT15671 and the serial number is 2010 RU 55997 on the tractor. I am checking before I get into something before I wish I started it.
Thanks
Phil
roden
08-30-2004 18:33:04
 Re: Sleeve liner for 2010 in reply to papafoutz, 04-19-2004 14:16:05
Phil,
Before you start looking for a liners look down where the liners would go,inside the block at the thin area between the liner holes,
GOOD chance your block is cracked .it would run from the bottom of the liner seat to the main bearings,If you had water in the oil before you tore the motor down,,LOOK for the cracks..
Al.
Mel
04-19-2004 21:09:06
Part number 15762 is the liner for a 2010, number 15761 is a liner for a 1010. The one for the 1010 has smaller sleeves than the 2010 and would not seal in the 2010 block. All the holes on the top deck are the same but different size sleeves. I have them both sitting in my garage and have done the comparisons before.
Mel
04-20-2004 09:40:50
 Re: Re: Sleeve liner for 2010 in reply to Mel, 04-19-2004 21:09:06
If your interested in the sleeve plate #15762, the one I have is nos. It is greased and in plastic. I'm asking $475 plus actual shipping.
wjogre
02-14-2006 20:35:27
 Re: Re: Re: Sleeve liner for 2010 in reply to Mel, 04-20-2004 09:40:50
mel-- did you ever sell that 2010 # 15762 sleeve deck-- if you haven"t please reply--I need one
Dan P.S.
12-20-2005 16:58:54
Do you still have this liner? I am interested in Buying it from you if you still have it.
Thanks
papafoutz
04-20-2004 12:08:03
Mel
I haven't had a chance yet to get it home to check it all out. Thanks for the info and I will keep you in mind about the sleeves. I have my one tractor down and been having trouble with the head on it. So I am cooling off about it. It was cracked and not repair right.
Thanks
papafoutz@hotmail.com
Heat Houser
04-19-2004 15:19:00
I checked the JD Parts catalog online and I think you transposed some numbers. I think you are looking for AT15761 which locator says that there are some out there at dealers in IA, MN, OH, LA, CO, VA. List is around $450. Or I think you could use AT15762 which is $560 with 2 in Milan Depot.
papafoutz
04-19-2004 18:44:31
 Re: Re: Sleeve liner for 2010 in reply to Heat Houser, 04-19-2004 15:19:00
Heat Houser
Yes I did transpose the number by accident It's been one of those days when nothing goes right.
Thank you for the info
Phil
